Date/Time: Thu, 16 Jan 2025 17:05:41 +0000
Chart Calculator Tool
View Count: 1664
[2017-11-13 00:09:28] |
User734705 - Posts: 1 |
Hi, I am new to Sierra Charts. I am liking how snappy it is and how economical it is with computer resources. I have a question re the Calculator Tool. Is it possible to display the Currency Value in a currency other than the exchange currency? eg. The mini Nikkei on the OSE is displayed in JPY - I would like to be able to see it in say USD or AUD. Thank you, Peter |
[2017-11-13 20:46:17] |
We will see about adding this to that drawing tool. Currently it is not supported.
[2017-11-15 09:59:23] |
This will be supported in the next release.
