Date/Time: Thu, 16 Jan 2025 16:08:14 +0000
bitfinex market data/book feed changed radically
View Count: 1042
[2017-11-12 23:40:13]
4646ed - Posts: 230
bitfinex market data/book feed changed radically this weekend: before it was showing market depth from at least several hundred to a thousand dollars below and above current market price. Now it shows market data about 25 above and 25 below. Even though BTCUSD is moving around a 1000 a day. to see the data over this small range eliminates the usefuless of having the data. Without expanding the zoom beyond practicality, figures in the DOM are squished together. here's a picture.
Date Time Of Last Edit: 2017-11-13 23:15:51
imagescrunched together.PNG / V - Attached On 2017-11-12 23:38:56 UTC - Size: 21.37 KB - 315 views
[2017-11-13 04:29:01]
4646ed - Posts: 230
any ideas? what's causing this? did the market depth data feed parameters change or did i mess up my chart settings somehow?
Date Time Of Last Edit: 2017-11-13 04:34:47
[2017-11-13 08:11:07]
4646ed - Posts: 230
I;ve gon through all the settings i can think of. Anyone have any ideas?
[2017-11-13 19:14:56]
You need to update to the current version of Sierra Chart:
You need to use this setting to combine the market depth data into larger increments:
Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu)
Also we did not make any changes. There is a certain algorithm which is used to combine market depth data on our server into larger increments, but nothing has changed with that.
Date Time Of Last Edit: 2017-11-13 19:16:19
[2017-11-13 23:14:09]
4646ed - Posts: 230
ok. That helped with the ratios -- but it still doesn't fix the depth of the book. Last week, and for the last 6 months I have been trading BTCUSD on bitfinex, I have had access to around a $1000 or more of book values -- 500 above and 500 below current price. Now there is only 25 above and 25 below.
On their website they have a setting where you can change the granularity of the book from 1 to 10 to 100. Sierra Charts last week looked the same as if it was on a granularity of 10 -- but now it's on 1. Meaning only a small portion of the book is available/visible.
Did bitfinex change the nature of the book data it sends to you? Or is there another setting that I dont know about.
Date Time Of Last Edit: 2017-11-13 23:21:05
[2017-11-14 05:07:37]
We are working on new integration to this exchange. We are not willing to do any further work on the old integration now. They must have changed something on their side.
