Date/Time: Thu, 16 Jan 2025 17:05:09 +0000
TPO Count and Countdown Timer
View Count: 2043
[2017-11-12 11:48:46] |
marty_nv - Posts: 85 |
1. Is it possible to calculate TPO Count above and below POC with % above and below POC? Example: 50-25%/150-75% Where if Total TPO count was 200 then 50 TPOs above POC=25% and 150 TPOs below POC=75%, able to be displayed on screen through "Text Display For Study"? See attachment 1. 2 Is it possible to direct "Countdown timer" to countdown Time Remaining in TPO Chart set to minutes? See attachment 2 |
pat 171112-1 SC TPO Count.png / V - Attached On 2017-11-12 11:43:57 UTC - Size: 97.17 KB - 465 views pat 171112-2 SC TPO Countdown TImer.png / V - Attached On 2017-11-12 11:45:43 UTC - Size: 75.16 KB - 394 views |
[2017-11-14 07:35:02] |
1. This will be added to the next release. But the information will be displayed in the Chart Values Window for the chart. 2. Here is the documentation for the Countdown Timer for TPO Profile Charts: Countdown Timer: Countdown Timer on TPO Profile Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-14 07:35:59
[2017-11-15 13:12:23] |
Thank you for all your valued support. The TPO Chart Values Window shows a number of important, relevant SC calculated values (see attachment 1). As opposed to showing some of them as Region 1 study display, is there a way to access the SC Calculated values and plot them as a subgraph below a TPO chart. I watch 7 TPO charts per symbol, numerical displays are not nearly as helpful as graphics and plots (the finest TPO Charts). But I don't know how to access these values except by mouse hover, very impractical for me most of the time. Of course the important guidelines (POC, HI LO Value Area Lines, Initial Value Extension Lines and many others) are handily configurable for ease of use in Region 1. See attachment 2. But evaluating for example the TPOs Above/below POC (or % above/Below) or Tracking TPOs above or below upper or lower extensions (Very important info--great work!) for me would be much better used if displayed in a plot either relative to price in region 1, or as stand alone studies in a subgraph. If there is documentation to access these figures, do post a link. Thank you for your patience with me and all your help over the years. |
pat 171115-1 TPO Chart Values Window.png / V - Attached On 2017-11-15 12:36:12 UTC - Size: 51.07 KB - 348 views Attachment Deleted. pat 171115-2 TPO Chart With Many Chart Value Window Values p.png / V - Attached On 2017-11-15 13:11:13 UTC - Size: 84.18 KB - 358 views |
[2017-11-15 18:11:03] |
No there is not a way to access the TPO Profile values other than the ones available in the Study subgraphs, but we will add that capability later on.
[2017-11-15 19:12:04] |
we will add that capability later on. Splendid! I love your work. |
