Date/Time: Thu, 16 Jan 2025 16:11:37 +0000
Color Bar Based on Alert Conditions only goes back so far, then stops as interval reduced
View Count: 908
[2017-11-11 21:56:04] |
User68474 - Posts: 201 |
I'm finding strange limitations to a simple "Color Bar Based on Alert Conditions" alert as far as how far back in time the alert will print. The formula is a simple "=C>O" and "=C<O", then color bar a certain color. It works fine, but stops functioning (coloring the bar) abruptly after going a few days back. Only a portion of "Number of Days to Download" seem to be printing color alert bars. It also seems to vary, based upon Bar Period Type and/or Interval Settings. No problem for Days, 240min, 120, 60, 30min. Starts to break down on 15 min. interval on a 50 day load up. Less and less alerts as time varied down to 1 minute. Is this normal?
[2017-11-11 23:18:19] |
This is controlled through this Input with the study: Color Bar Based on Alert Condition: Number of Bars to Calculate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-12 03:11:52] |
Wow. I totally overlooked such a basic setting. Shame on me, yet again! Thnx.
