Date/Time: Thu, 16 Jan 2025 16:18:27 +0000
Chatbook Shortcuts
View Count: 680
[2017-11-10 15:19:31] |
Frank Ace - Posts: 12 |
Am I able to set keyboard short cuts to a specific loaded chartbook? since I got more than 3 and switch between previous and next chartbook is not efficient.
[2017-11-10 19:34:16] |
No but there are Control Bar buttons: Control Bar: Control Bar Chartbook Buttons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
