Date/Time: Thu, 16 Jan 2025 16:13:04 +0000
Question about ETF
View Count: 1258
[2017-11-10 08:21:28] |
User164231 - Posts: 278 |
Hi, Was looking at SMH and saw the last candle bar is all the way down. Is it my wrong doing on SC setting or? Please advise. |
Private File |
[2017-11-10 17:21:52] |
We see you are using Interactive Brokers. Refer to this particular section in help topic 2: Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.2.6: Removing Permanent Data Errors from Real-time Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-11 09:47:20] |
Thanks and I have unchecked the real time data. Hope all is well.
