Date/Time: Thu, 16 Jan 2025 16:15:30 +0000
How to zoom out on a point in chart without date moving forward
View Count: 2931
[2017-11-10 05:09:19] |
User164231 - Posts: 278 |
Hi I currently have my mouse set to 'control the zooming in and out on a chart' in global setting. But for example when I point my mouse to a candle (say left portion of a chart) the chart keeps moving to the right when I am scrolling/zooming in. How do I lock to that candle where I want to zoom in. Thanks. |
[2017-11-10 18:14:57] |
But for example when I point my mouse to a candle (say left portion of a chart) the chart keeps moving to the right when I am scrolling/zooming in. Based on how Sierra Chart works, this is not making sense. Merely moving your mouse pointer around is not going to cause any movement of the chartDescribe exactly what you are doing to "zoom in". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-11 09:43:23] |
Hi, Let me try again, say I have zoomed out on a daily view chart with 10 years data. Then I found a candle which catches my eyes and I move my mouse over to that candle. Now, how do I, by pointing my mouse on this candle, start to scroll to zoom in on this candle without the chart moving away from this candle? Hope this is clear to you. |
[2017-11-11 23:02:57] |
Here are the specific instructions for this: Working With Charts: Zooming In and Out Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-12 04:27:38] |
HI I tried that and the whole candle filled the screen. Is there a progressive way of zooming in a point?
[2017-11-12 20:03:38] |
Specifically what we referred you to is this section here: Increasing bar spacing on a chart is a method by which you can expand horizontally or zoom-in an area on the chart. To zoom-in to an area of the chart: Move the chart scrollbar at the bottom of the chart so that the last bar of the area you want to zoom-in to is at the end of the chart window. Increase bar spacing to zoom-in.
[2017-11-13 06:31:06] |
Didn't help but still, thanks.
