Date/Time: Thu, 16 Jan 2025 16:11:19 +0000
[Programming Help] - Extended lines
View Count: 1024
[2017-11-10 00:31:48]
samual sprat - Posts: 343
I have a daily chart which I use to draw rays from specific opening candles. The rays on that chart are not extended until intersection. I use a study price overlay to pull those rays onto other charts. Is it possible using a study to take the ray data, run some logic against it and display the overlay if true? For example...
If the source chart has a daily candle that engulfed the previous daily candle then show the ray on the destination chart.
Thanks!
S
[2017-11-10 04:24:57]
Yes. Also we do not think you are referring to a Ray drawing tool but to a study.
All of this is certainly possible using ACSIL. Refer to:
Advanced Custom Study Interface and Language (ACSIL)
