Date/Time: Thu, 26 Sep 2024 23:31:16 +0000
[User Discussion] - chart dom
View Count: 1652
[2017-11-09 22:56:51] |
N!co - Posts: 140 |
Hi can you please the "market depth incredement in ticks" also apply to the other options in the customize DOM columns thank you very much |
chartdom.png / V - Attached On 2017-11-09 22:56:43 UTC - Size: 117.69 KB - 468 views |
[2017-11-18 16:41:39] |
N!co - Posts: 140 |
Support , please have a look at this issue
[2017-11-19 20:44:45] |
We will have to look at this later on.
[2017-11-24 12:26:45] |
N!co - Posts: 140 |
support, any update on this issue ? thank you very much |
[2017-12-16 21:32:25] |
The answer at post #3 remains the same for now.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-16 21:32:49
