Date/Time: Thu, 16 Jan 2025 16:23:32 +0000
The new ACSIL function that reads Intraday records contained within a chart bar.
View Count: 781
[2017-11-09 19:54:11] |
Zosimus - Posts: 345 |
I read on the What Is New page that there is a new ACSIL function that reads Intraday records contained within a chart bar. Is this function already documented? |
[2017-11-09 20:42:04] |
No, but there are code examples for it. Look at the scsf_ReadChartBarRecordsFromUnderlyingIntradayFileExample function. Refer to: https://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html#SearchingSourceCodeBuiltIn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
