Date/Time: Wed, 12 Mar 2025 16:15:51 +0000
customize trading dom columns
View Count: 4074
[2017-11-09 18:39:40]
User126996 - Posts: 30
Chart Trading and the Chart DOM: Customizing Trade DOM and Chart DOM Columns
I read this and I couldn't find it on my platform. I am looking to add some columns to my trading dom....thanks.
[2017-11-09 18:51:03]
Update Sierra Chart to the current version following the instructions here:
[2017-11-09 18:59:10]
I have the updated version. I still cannot find
Trade >> Customize Chart/Trade DOM Columns.
[2017-11-09 19:00:07]
To customize the columns for the active Chart or Trade DOM, select Trade >> Customize Chart/Trade DOM Columns. Since version 1516, the column customization applies to the active Chart or Trade DOM. They are no longer global. They need to be set individually for each Chart and Trade DOM as needed.
this is what I'm going off of.
[2017-11-09 19:02:28]
i'm using version 1641
[2017-11-09 19:12:38]
You must be a TransAct user. Therefore, you need to use a Sierra Chart direct account for this:
Direct Sierra Chart Account
[2022-05-18 08:03:13]
User697582 - Posts: 2
So these features will not work in Trial mode correct?
Thank you.
[2022-05-18 14:19:21]
John - SC Support - Posts: 38612
These features work in Trial mode. This is a very old post and was related to some specialized software back at that time.
