Date/Time: Thu, 16 Jan 2025 13:18:50 +0000
GOTO date on chart from spreadsheet
View Count: 800
[2017-11-09 16:07:52] |
User170575 - Posts: 221 |
Hi---is there a way from a spreadsheet cell of date and time --- to go directly to that date and time on a chart? I know you can do it from alerts but I use the spreadsheets alot and find it tedious to find the point of interest be scrolling back and forth on a chart that goes back years. Many thanks, Cy |
[2017-11-09 19:44:15] |
No, there is only the Chart >> Goto Date-Time command.
