Date/Time: Thu, 16 Jan 2025 13:05:00 +0000
Percent Change
View Count: 1406
[2017-11-09 15:54:28] |
User28914 - Posts: 87 |
I have a client that wants to use the Percent Change study but can it be a percent change for the week, month, year? Or is only available from the Previous Close?
[2017-11-09 19:28:35] |
Yes. The documentation for the Percent Change Since Open study explains how to do this: Percent Change Since Open That is done through the Start Time input and adjusting the data loaded into the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-09 19:30:09
[2017-11-09 19:34:54] |
Thank you!
