Date/Time: Thu, 16 Jan 2025 13:07:23 +0000
Volume 30 min. time frames
View Count: 700
[2017-11-09 15:34:16] |
User72965 - Posts: 115 |
Can I some how start a volume for every 30 min. time frame??? I use Profile chart. And would like to know the volume and delta on each... That is a + or - Delta from the previous 30 minutes.... I trade the E Mini> But I'm sure it could be used on any Instrument.... If not : Maybe you could pursue this matter .. Thx Gene Sheldon (genesheldon43@gmail.com A change ck. your account~~~) |
[2017-11-09 18:49:46] |
We do not understand this.
