Date/Time: Thu, 16 Jan 2025 12:56:00 +0000
Some ticks seem wrongly stamped Bid or Ask volume
View Count: 1304
[2017-11-09 07:39:38]
gomifromparis - Posts: 244
I'm investigating why my NT8 orderflow has different Delta readings than Sierra. They both use Rithmic, there should be no difference.
They both generally match, but still, sometimes, there's a difference on some ticks, leading to differences in overall delta.
After investigation, it looks like some ticks on Sierra seem wrongly stamped as bid/ask.
Example here 15:02:52 on the DAX, GMT+1 time.
We have 2 ticks during this second, they both happen at the bid, but the second one is marked 'Ask Volume'.
imagebidaskticks.png / V - Attached On 2017-11-09 07:38:46 UTC - Size: 66.81 KB - 335 views
[2017-11-09 11:02:09]
User336946 - Posts: 37
Few questions:
1) Is the overall volume correct, it’s just on the wrong side? Or is the volume wrong randomly too?
2) Does delete/redownload fix it?
[2017-11-09 11:13:57]
1)Volume is correct, only on the wrong side.
2)Nope
[2017-11-09 16:22:57]
Maybe it's because on that tick the market went up, so it was forced to be ask volume, even if it's at the bid.
Date Time Of Last Edit: 2017-11-09 16:27:11
[2017-11-09 17:43:53]
All of this is explained in the Definitions section here:
Numbers Bars: Definitions
Refer to the Bid and Ask Trade Volume sections.
[2017-11-09 17:56:14]
OK got it. Rithmic provides the historical bid/ask. thanks
