Date/Time: Thu, 16 Jan 2025 16:50:31 +0000
When using a 2xTick Size in chart settings, some ticks are wrongly mapped
View Count: 950
[2017-11-08 23:26:30]
gomifromparis - Posts: 244
Here is example on 6E.
I attach original tick size 0.00005 and same chart on 0.0001 tick size.
Some ticks on are wrongly mapped on the 0.0001 chart, so 2 price ticks separated by 0.0001 are now separated by 0.0002
It happens for only a couple price levels, but these price levels will always be wrongly mapped.
imagetickmapping.png / V - Attached On 2017-11-08 23:26:15 UTC - Size: 35.55 KB - 390 views
[2017-11-09 00:39:55]
We will try a relatively simple patch for this, but we are afraid of what problems it can cause.
We will let you know when it is out.
[2017-11-14 05:16:27]
Can you see if this is resolved in prerelease 1643.
[2017-11-14 09:02:31]
For now it seems changing the tick size doesn't do anything on the 6E chart, see 0.00005 vs 0.0001
imageticksize.png / V - Attached On 2017-11-14 09:02:28 UTC - Size: 25.43 KB - 304 views
[2017-11-14 17:21:04]
Changing the Tick Size is not going to alter the price data in any way whatsoever.
Previously your question was about the Volume at Price data.
Date Time Of Last Edit: 2017-11-14 17:21:21
[2017-11-14 17:51:34]
OK I thought TickSize impacted everything.
Yes NumberBars are correct now.
[2017-11-14 18:02:39]
OK good.
