Date/Time: Thu, 16 Jan 2025 13:17:58 +0000
tick range values
View Count: 788
[2017-11-08 20:51:53] |
User635423 - Posts: 51 |
1. How can I calculate the maximum tick range from high to low in a single day for the past 90 days. 2. How can I calculate the average tick range for the past 45 bars within Monthly, Weekly, Daily, 60M, 15M, 5M, 2M, and 1M charts. Thanks |
[2017-11-09 04:33:46] |
The most help we can provide you is to refer you to this study here: Previous/Period OHLC-Variable Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-09 04:34:16
