Date/Time: Thu, 16 Jan 2025 13:05:05 +0000
Daily P/L in Trade window.
View Count: 674
[2017-11-08 14:30:53] |
User170575 - Posts: 221 |
Good morning, Is there a way to set the default of the "DlyPL" window to equate to the point gain on one contract rather than reflecting the pt gain by the number of contracts? Thx, Cj |
[2017-11-08 15:02:24] |
ticinotrader - Posts: 397 |
this would be a great enhancement!
[2017-11-08 18:41:28] |
This cannot be supported. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#ProfitLossFormat Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
