Date/Time: Thu, 16 Jan 2025 12:51:44 +0000
Numbers Bars - Coloring method - v1639
View Count: 879
[2017-11-08 09:31:11]
User590848 - Posts: 13
I don't know, if I do something wrong, but I can't get same result since new update (1639).
my setup:
Bid Vol x Ask Vol
Based on Diagonal Dominant Side AskVol BidVol Percentage
0.25, 0.5, 0.75
seems like.. if I change color in Range 0, it has no effect..
imageschNB.jpg / V - Attached On 2017-11-08 09:29:44 UTC - Size: 258.5 KB - 321 views
[2017-11-08 15:10:03]
Follow the instructions here to attach a Chartbook with that particular chart:
[2017-11-08 15:42:59]
here is chartbook
attachmentNB_color.cht - Attached On 2017-11-08 15:42:01 UTC - Size: 30.57 KB - 381 views
[2017-11-08 18:41:41]
John - SC Support - Posts: 37270
There was a change made to that particular Text Coloring to make it consistent with the other Diagonal Text coloring methods. In the past, it would color both the Bid and Ask for all values. This change now makes it so that the Bid or Ask Side is only colored if it is diagonally dominant. If it is not dominant, it is not colored. The choice of color is still based on the same percentages as before and uses either the standard Coloring or the alternate Text Coloring if set.
You can find the description for how this is now being done here:
Numbers Bars: Text Coloring Based on Dominant Side AskVol BidVol Percentage
