Date/Time: Sun, 24 Nov 2024 02:27:50 +0000
iqfeed back adjusted #C contracts
View Count: 1963
[2013-09-12 02:28:10] |
User22396 - Posts: 191 |
indices rolled to dec tonite with the start of the globex session but my #c index contracts still have the gaps...doenst iqfeed automatically adjust? @es#c, @ym#c, @nq#c |
[2013-09-12 03:16:31] |
No. You have to re-download the data through the Edit>> Delete All Data and Download menu.
[2013-09-12 03:19:10] |
tried that but still doesnt look like it downloading
[2013-09-12 03:47:52] |
How could that be? That command is going to completely delete all of the data and re-download it. When you execute the command, the chart is going to go blank at first. Unless it is blank and then you are not getting new data? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-12 03:52:09] |
chart does not go blank... all it does is the yellow box 'downloading data blah blah' then the green box 'hist download complete etc' |
[2013-09-12 03:54:11] |
This means you did not select this command: Edit>> Delete All Data and Download Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-12 04:03:03] |
yes that is the command i executed numerous times...still same data you could technically say the chart goes blank for like 1 second while it goes from yellow box to green box any chance you could look at your iqfeed @ES#C to see what data you show? iqfeed currently shows 1681.50 -0.075 (dec) sep close 1688.75 dec close 1682.25 |
[2013-09-12 04:31:16] |
You must not have selected that command. Did you select it from the Edit menu? Or you have set Sierra Chart to download a small amount of data. Refer to help topic 42 here: http://www.sierrachart.com/index.php?l=doc/helpdetails42.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-12 04:32:29
[2013-09-12 08:46:02] |
normal guy - Posts: 16 |
You may already figure this out. Here's how I resolved mine. You have to delete it from the original SC where you run IQfeed, not from your trading SC. SC, running IQfeed does not need to open chart however in this case you temporarily open the charts then delete them from where you see the gap. You can close it after you see the adjustment. It will be good until next contract expiry date. Hope this helps. |
[2013-09-12 09:55:05] |
Based upon what they have described, we do not believe they are performing a Delete All Data and Download operation from a copy different than where the chart data file originates from.
[2013-09-12 12:55:14] |
I was performing that edit > delete all data and download the problem was on DTN's side... The continuous back-adjusted contract is not immediately back-adjusted. This process happens overnight at differing times. I have verified that the history for the three contracts you listed is now back-adjusted. Please let me know if you have any additional questions. Thanks,Nathan W. Bartsch - Senior Software Engineer - Telvent DTN |
