Date/Time: Thu, 16 Jan 2025 16:19:48 +0000
FANG+ Index Future ticker sybmbol?
View Count: 1535
[2017-11-08 09:14:31] |
User941322 - Posts: 5 |
Title says it all, will this be available this afternoon? Kind regards, Tsige. |
[2017-11-08 18:56:45] |
We do not know what you are referring to at all.
[2017-11-08 19:15:25] |
Then excuse me. There is a new index future trading on ICE named the NYSE FANG+ index future that represents the top 10 tech stocks on the NYSE. trading since this afternoon. Was looking if the symbol was there already but it isn’t. Sorry.
Date Time Of Last Edit: 2017-11-08 20:53:08
[2017-11-08 20:53:32] |
OK we see you are using Interactive Brokers. We can add that symbol. Also you have the ability to edit your post using the "Edit" link at the lower right. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-08 21:01:14] |
Top service as always, Thank you guys alot!
[2017-11-10 00:01:32] |
We should have this done today.
