Date/Time: Sun, 24 Nov 2024 03:14:02 +0000
[User Discussion] - Horizontal lines out of sync after I save and close and reopen
View Count: 1416
[2013-09-11 22:22:37]
Heather ODonovan - Posts: 1
I draw horizontal lines on my chart showing cumulative delta volume, and I draw horizontal lines to mark pivot points. If I leave Sierra Charts open without closing it down, it will stay just as I have drawn them, but whenever I save what I have done and close Sierra Charts and then bring it back up, my lines are off - I just did this now (to reboot my computer) and the lines I have drawn have moved backward and up higher than they were before, so they're no longer valid for me to refer to and I have to draw them all over again - is there something else I need to do to keep the lines in tact? I use IQFeed as my data provider if that has any bearing on the issue - thanks very much! :)
[2013-09-12 00:55:39]
Sawtooth - Posts: 4118
Cumulative Delta has a starting point. If you set 'Reset St Start Of Trading Day' to Yes, it starts counting again every day for one day only. If you set it to No, it starts counting at the number of Days To Load back from today. So, the way to keep your lines in the correct places is one of these:
1) Set the Use Number of Days to Load to 0. This will load all data from the .scid file, but if you use a continuous contract, load time can be lengthy.
2) Set the Use Date Range to a From date and leave the To date blank.
