Date/Time: Thu, 16 Jan 2025 13:15:09 +0000
connection info popup
View Count: 590
[2017-11-07 18:40:39]
User98657 - Posts: 329
Could you PLEASE make, or tell me how to make, the Connection Info pop up stay on top?
When I reconnect that popup gets buried beneath the other active windows and i end up having to minimize and search for it.
it should just appear on top of the existing active window(s) and stay there until you verify the question.
[2017-11-07 19:18:37]
We are not really clear what you are referring to. We do see you are using TransAct so maybe you are referring to the bridge program.
That is not anything Sierra Chart has any control over. It is a TransAct program.
