Date/Time: Thu, 16 Jan 2025 13:03:35 +0000
% change since open still not working correctly since 1620
View Count: 1065
[2017-11-07 14:16:41] |
nioko54130 - Posts: 108 |
Hello dear support, the percentage change since open doest work properly since the 1620 SC released. Any solution to not be forced to rebuild all with this new % change since open you've made? or a way to use the old studies? Thank's |
[2017-11-07 14:21:07] |
Sorry, the problem seems to be solved in the 1638 SC released. I have just have to change the "value format" of my studies setting and put it in "percentage" Thank's |
[2017-11-07 17:54:29] |
There are no changes between the 1638 prerelease and the current release 1635 in regards to this. I have just have to change the "value format" of my studies setting and put it in "percentage" This is what you need to do but this happens automatically upon updating to the current version of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-07 17:56:23
[2017-11-07 22:00:10] |
Not for me, probably because i have used it before in an old chartbook and have tryed to reload this old chartbook. Problem solved finnally. Thank's |
