Date/Time: Sun, 19 Jan 2025 19:57:10 +0000
Add a price alert to alerts manager by drawing a horizontal line
View Count: 3129
[2017-11-07 14:00:25] |
Nick - Posts: 15 |
I use horizontal alert lines all the time, but the problem is the alert only triggers if I have the chart (with the alert line) open and set to the correct symbol. I trade stocks and I'm constantly flipping through charts and setting alert levels using a custom alert line hotkey. I can't keep all these windows open and I find myself missing alerts on a daily basis. The only solution I know of is to use the alert manager which does monitor price alerts in the background. However with alert manager I have to manually type in symbols and price alerts. The process is slow and I would much rather draw a line and have it automatically added to the alert manager. Would it be possible to add such a feature with a custom indicator or tool? I'd be willing to hire a developer if necessary. |
[2017-11-07 18:38:58] |
It is possible to right-click on the chart and select Add Symbol Alert. This is documented here: Alerts Manager: Symbol Alerts Would it be possible to add such a feature with a custom indicator or tool? I'd be willing to hire a developer if necessary. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-07 20:57:01] |
Nick - Posts: 15 |
Perfect! Sierra Chart never ceases to impress. I found plenty of goodies under "customise chart shortcut menu" settings.
[2018-05-07 20:17:51] |
User337551 - Posts: 7 |
Nick, if I understand your question correctly, you might take a look at drawing a line at the price you want to be alerted to and then add an alert to the line. When price hits the line, you get an alert.
[2018-05-07 23:03:41] |
Here is more information about this related to a default chart drawing alert configuration: http://www.sierrachart.com/index.php?page=doc/Tools.html#DefaultChartDrawingAlertConfiguration
