Date/Time: Thu, 16 Jan 2025 13:06:10 +0000
Customised Toolbar
View Count: 678
[2017-11-07 13:03:49]
Dom7364 - Posts: 257
Is there a file that I can save from one PC to another to import my customized toolbar?
[2017-11-07 16:04:05]
Sierra Chart - Max - Posts: 5778
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
Sierra3.cfg (Contains all of the global settings in Sierra Chart. This includes settings set through all of the configuration windows under the Global Settings menu including all of the Control Bar configurations. Chart specific settings, like the settings in Chart >> Chart Settings, are held in Chartbooks and not this file. Sierra3.cfg does not include Account related settings or Global Symbol Settings and can be safely shared with others.)
The Control Bar is the Toolbar:
Control Bar
Sierra Chart Support
[2017-11-07 18:34:57]
When you copy this file, make sure the source and destination instances of Sierra Chart are not running.
