Date/Time: Thu, 16 Jan 2025 12:52:19 +0000
Reduce space between Studies/Oscillators
View Count: 998
[2017-11-07 12:02:08]
User164231 - Posts: 278
How do I close up the space between Studies/Oscillators?
Thanks.
Private File
[2017-11-07 16:06:39]
Sierra Chart - Max - Posts: 5778
Refer to Adjusting the Height of Chart Regions By Using the Values Scale here:
Working With Charts: Chart Window and Regions
And to the Adjust Regions documentation here:
Chart Drawing Tools: Adjust Regions
Sierra Chart Support
[2017-11-07 18:15:12]
Actually looking at the chart image you attached, what you want to do is reset the scale for those chart regions. The easiest thing to do is just select Chart >> Reset Scales.
Also refer to:
Chart Scale and Scale Adjusting: Resetting the Scale
Date Time Of Last Edit: 2017-11-07 18:16:33
