Date/Time: Thu, 16 Jan 2025 12:59:24 +0000
Is it possible to have more than one study using Value On High/Low without overlap?
View Count: 784
[2017-11-07 08:39:27] |
User023822 - Posts: 15 |
Hi, I use Value On High/Low to display bid & ask volume above and below price candles. Is there any way of being able to display another study using VOH/L on the same chart without overlap - I would like to be able to also display total volume and bid & ask difference above/below each candle as well as actual bid & ask volume? If not, is vertical adjustment of VOH/L someting that could be added in the future? Many thanks |
[2017-11-07 08:55:24] |
We are actually working on a study, that will be able to accomplish this. Should be out in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
