Date/Time: Thu, 16 Jan 2025 13:01:39 +0000
Additional SIM 101 Account
View Count: 898
[2017-11-07 01:04:30] |
User607495 - Posts: 10 |
I am going to take a Combine with TopStep Trader. I am going to copy and paste the instruction.. Is this possible to use with my current live and sim account AC82584? thanks Todd Sierra Chart Connection Instructions Since you will be using the CTS data feed, you will be required to complete the CME Market Data Requirements for CTS. Please complete this step before you move on to the connection to Sierra Chart! Sign into CTS in order to fill out the one time requirement from the CME, then you will not be asked to do this again. Please click here in order to complete this step. Please change the Firm name from "CTS" to "PTP". You will use your username and password (case sensitive) that you received in the Account Information email. When filling out the form, please select "Non Professional" for "Type of User". Launch Sierra Chart platform. To connect please click on File >> Data/Trade Service Settings >> Select CTS T4 FIX [trading] from the "Server" drop down list. In the Connection Details window please fill in the following: IMPORTANT! Always use Simulation Server. Server: Use Simulation Server Username: Found in Account Information email Password: Found in Account Information email Firm: PTP Here is an image of what the window should look like: Click OK to close the Data/Trade Service Settings window. In order to connect properly please ensure that Trade Simulation Mode is disabled (unchecked). Click on Trade >> Trade Simulation Mode >> if this is checked, please click to uncheck. Here is what it should look like: Click on File >> Connect to Data Feed. If you have any further questions, please contact us at support@topsteptrader.com |
[2017-11-07 10:55:47] |
To use the Combine with TopStep Trader requires that you have a direct Sierra Chart account: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
