Date/Time: Thu, 16 Jan 2025 13:15:36 +0000
[User Discussion] - Volume bard and volume filters
View Count: 1050
[2017-11-07 00:43:36] |
Usermb - Posts: 126 |
Using volume bars without any volume filters seems to be working very fine, just as expected. See j6_vol_bars_5000.png If I apply a volume filter "Exclude <= 1" and leave "Filter Trade Completely" unticked, I expect to see the same chart as without filtering, except for the Volume indicator, which should contain for every bar "5000 - sum(1 volume trades)", but this does not appear to be the case. It instead looks as in j6_vol_bars_5000_filter_lte_1.png, which appears to be random. Filtered "Exclude <= 1" and with "Filter Trade Completely" also ticked it appears to be working as expected, see j6_vol_bars_5000_filter_lte_1_completely.png |
j6_vol_bars_5000.png / V - Attached On 2017-11-07 00:40:37 UTC - Size: 34.97 KB - 364 views j6_vol_bars_5000_filter_lte_1.png / V - Attached On 2017-11-07 00:40:42 UTC - Size: 24.61 KB - 363 views j6_vol_bars_5000_filter_lte_1_completely.png / V - Attached On 2017-11-07 00:40:46 UTC - Size: 32.3 KB - 332 views |
[2017-11-07 03:54:38] |
This is something that we cannot spend time with. It is marked as a User Discussion and can be discussed among users. It is very technical and complicated, and unnecessarily takes engineering time. Although upon a little bit of additional analysis of what you are saying, it should be clear that altering any of the volume filtering settings, is going to cause a difference with volume-based bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-07 04:13:32
