Date/Time: Thu, 16 Jan 2025 13:05:13 +0000
Do not see M indicator beside symbol
View Count: 959
[2017-11-06 21:36:15]
azamatbagatov - Posts: 5
Hi, after purchasing the market data and proper feeds, I still do not see the M indicator beside the symbol. I am not sure if this means the symbol is not being quoted in real time, but there is a time delay and I see it is not showing after hours price change although there currently is. It is not for 1 specific indicator but for anything I search up that falls under the us equities. Thanks.
[2017-11-06 22:11:13]
You are not logged into Sierra Chart using the correct account.
You need to login using the same Username/Account Name you have logged into this Support Board with. Follow the instructions here:
Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name
Otherwise, your Sierra Chart account is properly set up for for the Sierra Chart Exchange Data Feed and will provide US equities data in real-time.
[2017-11-06 22:58:55]
Ok thank you. I am not subscribed to any market data on the IB end, only on the sierra chart end. Do I have to subscribe to market data from IB to be able to place trades on sierra chart and get the full market depth data? Thank you.
[2017-11-06 23:12:50]
No you do not.
