Date/Time: Thu, 16 Jan 2025 13:10:43 +0000
CL Futures - 60 min bars close 15 min later
View Count: 733
[2017-11-06 18:26:19] |
User859795 - Posts: 51 |
Hello, I just realized that the 60 min bars on CL close 15 min later, so they close at hour:15. How can I fix it? Thanks! |
[2017-11-06 19:51:21] |
This is controlled by the Session Times >> Start Time setting. Refer to: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
