Date/Time: Thu, 16 Jan 2025 19:00:55 +0000
[User Discussion] - Using Sierra Chart on Wine on Linux in production
View Count: 4171
[2017-11-09 22:22:59]
AlexPereira - Posts: 197
I made all of my custom studies using native linux mingw-g++ cross-compiler
Second that, I also followed your tutorial there.
Also, qtcreator works very well also ( actually my fav ).
[2017-11-09 22:32:30]
ganz - Posts: 1048
AlexPereira
if anyone ever reported this to the wine devs
I did some reports as a crossover subscriber.
Talked to devs with no result.
They take care for Office apps and games first and their bug tracker is full for decades.
So some issues was repaired by SC Team. Some of them has no solution.
So answer is No.
Date Time Of Last Edit: 2017-11-09 22:33:32
[2017-11-09 22:48:27]
Yes, please do.
https://youtu.be/hKi5zC4pog8 ( more generic movement )
and
https://youtu.be/qGk9yJqhdbY ( just noticed that if i am reallly slow, it uses way more cpu )
just uploaded
Date Time Of Last Edit: 2017-11-09 22:51:10
[2017-11-09 23:14:52]
ganz - Posts: 1048
AlexPereira
This low efficient behavior is the same for nvidia.
It was extremelly interesting.
And thank you a lot for your time.
[2017-11-09 23:20:09]
Sorry if it was all for nothing. I coded a especific ACSIL tool just for movement and zooming, so it was actually the first time I did it and saw it.
Tomorrow I will check if it also happens on windows.
[2017-11-20 23:14:58]
ganz - Posts: 1048
AlexPereira
never mind, forget it
let's leave SC on wine and go back to planned native linux SC version you asked for
this is another strange behaviour from a lot of linux newbies
what is the problem to build your own qt5 charting app that meet all of your needs?
so just try to build simple candlestick chart app and check a performance condition
did you try it to make? -I did.
is the result the same than for SC on windoze? - definitely it is not. it is much worse
the fact is Qt5 has the same performance level as .Net/WPF that means - bad.
Is there another cross-platform graph toolkit to make it ready for production with better conditions? - everybody will be happy to know this news I believe :)
