Date/Time: Thu, 16 Jan 2025 12:51:35 +0000
vertical session line goes back to 00:00
View Count: 878
[2017-11-06 14:14:35] |
User859795 - Posts: 51 |
hello, yesterday I enabled the Vertical Session Line for my ES and CL charts, i'm on Pacific time and i'd like to see the session open time (1400) on the charts. I also disabled the Evening Session. The lines were fine yesterday (I understand that the historical vertical lines won't show the correct time anymore), but today the 1400 hour lines went back to 00:00. How can I fix that? Thank you, Zolie |
[2017-11-06 19:19:37] |
It sounds like you are referring to the Vertical Grid. Refer to the documentation here for this: Chart Menu: Vertical Grid (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-06 19:19:50
