Date/Time: Sun, 19 Jan 2025 06:30:46 +0000
Linking Charts of Different Time Frames to maintain the same time ratio?
View Count: 996
[2017-11-06 03:27:26] |
absorrel4 - Posts: 97 |
I know how to link charts so that if I change the timeframe on one chart it is automatically changed on the other chart. If I have two or more charts with different timeframes (e.g., 1 minute on one chart and 3 minute a second chart....a 1:3 ratio) can I link them so that the ratio difference is maintained. If I change the 1 minute chart to 5 minutes, the second chart is automatically changed to 15 minutes to maintain the 1:3 ratio?
[2018-03-28 00:31:54] |
I never received a reply for this question. Does anyone know if this is possible?
[2018-03-28 02:49:37] |
No.
