Date/Time: Thu, 16 Jan 2025 12:16:42 +0000
Bitmex stopped realtime data.
View Count: 1308
[2017-11-05 21:16:20] |
User198817 - Posts: 56 |
Realtime orderbook data is not being downloaded any more. Restarted the client, even downloaded latest version. It's just frozen. http://www.sierrachart.com/image.php?Image=1509916564938.png It's very critical that this works! :( |
[2017-11-05 21:32:23] |
If problem is on your side, please look at this ASAP
[2017-11-05 22:00:41] |
http://www.sierrachart.com/image.php?Image=1509919211795.png no data all atm. Tried reinstalling sierrachart in another folder, fresh setup, same problem. |
[2017-11-05 22:32:07] |
We are looking into this now.
[2017-11-05 22:56:09] |
We see the problem and we are resolving it now.
[2017-11-05 23:02:32] |
There it came back, thanks.
[2017-11-05 23:05:45] |
Great job on merging the price levels. Are you gonna prevent this from happening again in the future? |
[2017-11-05 23:37:27] |
Are you gonna prevent this from happening again in the future? Now that it is corrected, it simply cannot happen again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-06 01:09:14
[2017-11-06 00:17:44] |
Great, thanks for the clarification.
