Date/Time: Thu, 16 Jan 2025 13:00:28 +0000
Future Date
View Count: 970
[2017-11-05 18:40:11]
User00111 - Posts: 111
Why does not the correct date appear?
imageWhy does not the correct date appear.png / V - Attached On 2017-11-05 18:40:02 UTC - Size: 76.26 KB - 287 views
[2017-11-05 20:20:04]
What is the time zone for that chart? Refer to:
Time Zone Setting
There are two time zone settings. One of them is global and one of them is specific to an individual chart.
[2017-11-05 20:48:59]
The time zone is OK. Check the picture.
Thx
imageFuture Data_1.png / V - Attached On 2017-11-05 20:48:45 UTC - Size: 264.7 KB - 268 views
[2017-11-06 08:22:50]
OK we apologize. We did not notice there were no chart bars in those chart columns.
You need to not load weekend data. This is done through this setting here:
Chart Session Times: Load Weekend Data Setting (Chart >> Chart Settings >> Session Times)
Date Time Of Last Edit: 2017-11-06 08:23:50
[2017-11-06 10:37:04]
I've tried it all but it does not work. The future data not appers.
[2017-11-06 18:29:34]
When you set the chart to not load weekend data you will not see weekend data in the chart. Unless you are using reversed Session Times:
Chart Session Times: Why Reverse Session Times?
