Date/Time: Thu, 16 Jan 2025 12:18:17 +0000
cts t4
View Count: 1041
[2017-11-04 18:30:57] |
User841161 - Posts: 230 |
Been trying to configure Sierra with the cts t4 from dorman. Seems as if Sierra is set up to trade on simulation mode. I have to separate ids and psswd. One for Live trading and one for simulation. I want to get it set for live trading.
[2017-11-04 21:26:55] |
Here is the documentation about disabling Trade Simulation Mode: Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes Use your CTS live account information in: Global Settings >> Data/Trade Service Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-05 00:18:28] |
Ok, put the setting and brokers id and password in. When trying to put a order in, it is giving me this message. Trade Activity Log: File read result: 155 records inserted. 0 fill records inserted. 0 records filtered. | 2017-11-04 12:29:23 Trade Activity Log: File date-time limits: Sim records date-time limit is 2017-10-20 00:00:00. Non-sim records date-time limit is 2017-08-03 00:00:00. Non-sim fill record date-time limit is 2016-11-04 00:00:00. | 2017-11-04 12:29:23 Flagging to reload Trades list in charts | 2017-11-04 12:30:58 CTS order update (Rejected). Info: Failed to send to any executing group login. Internal Order ID: 373. Service Order ID: A3835F4D-062A-4CD0-B812-3EBDFD04F335. Symbol: SI.20171200.CME_CO | 2017-11-04 13:32:54 * CTS order update (Rejected). Info: Failed to send to any executing group login. Internal Order ID: 373. Service Order ID: A3835F4D-062A-4CD0-B812-3EBDFD04F335. Symbol: SI.20171200.CME_CO | 2017-11-04 14:17:09 * CTS order update (Rejected). Info: Failed to send to any executing group login. Internal Order ID: 373. Service Order ID: A3835F4D-062A-4CD0-B812-3EBDFD04F335. Symbol: SI.20171200.CME_CO | 2017-11-04 14:17:09 * CTS order update (Rejected). Info: Failed to send to any executing group login. Internal Order ID: 373. Service Order ID: A3835F4D-062A-4CD0-B812-3EBDFD04F335. Symbol: SI.20171200.CME_CO | 2017-11-04 18:59:40 * Flagging to reload Trades list in charts | 2017-11-04 19:08:57 Flagging to reload Trades list in charts | 2017-11-04 19:09:26 CTS order update (Rejected). Info: Failed to send to any executing group login. Internal Order ID: 374. Service Order ID: F98EA219-68D5-46F4-8F2E-2A43CC53EE6A. Symbol: CL.20171200.CME_NY | 2017-11-04 19:12:57 * |
Attachment Deleted. Private File |
[2017-11-05 01:09:58] |
CTS order update (Rejected). Info: Failed to send to any executing group login. Internal Order ID: 373. Service Order ID: A3835F4D-062A-4CD0-B812-3EBDFD04F335. Symbol: SI.20171200.CME_CO | 2017-11-04 13:32:54 * Your broker needs to contact CTS about this message. It is a CTS message and they will be able to help with it.Maybe it will go away, when the market opens. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-05 01:10:18
