Date/Time: Thu, 16 Jan 2025 12:02:33 +0000
Actual Price Line Visibility
View Count: 786
[2017-11-04 17:16:47] |
User463693 - Posts: 5 |
Hi. I'm not sure why but my actual price line is invisible. Where can I find the proper place to modify this function? Is there any possibility to automatically draw a horizontal line between the main chart anf region 2 where my indicator is? |
[2017-11-06 01:24:40] |
actual price line We do not know what you are referring to. Is this a study? Is there any possibility to automatically draw a horizontal line between the main chart and region 2 where my indicator is? Yes. Refer to:Chart Settings: Display Region Dividing Lines (Chart >> Chart Settings >> Grid menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-06 01:24:59
