Date/Time: Thu, 16 Jan 2025 12:13:08 +0000
Use Date Range in Chart settings does not work anymore with futures Data.
View Count: 945
[2017-11-04 10:00:53]
User889191 - Posts: 61
With equities data it works. With futures data(CQG) it loads current day. Please fix it. See example attached.
imageYM_ChartSettings.png / V - Attached On 2017-11-04 09:59:13 UTC - Size: 47.06 KB - 360 views
imageYM_Chart_loading_current_day.png / V - Attached On 2017-11-04 09:59:21 UTC - Size: 32.26 KB - 319 views
[2017-11-04 10:50:38]
This is a Continuous Futures Contract chart. In this case refer to this section here:
Date Time Of Last Edit: 2017-11-04 11:33:33
[2017-11-04 12:21:29]
It is not a data problem. All data is in historical file(see attachment). It is an issue with software that shows last day (2017-03-11) although I selected date range(2017-01-12 - 2017-10-15).
imageYM_Chart_hist_data.png / V - Attached On 2017-11-04 12:21:24 UTC - Size: 35.08 KB - 339 views
[2017-11-05 18:39:01]
OK we now understand what you are saying. To prevent the Current Quote data from being added to the chart, disable Chart >> Chart Settings >> Advanced Settings >> Allow Real-time Updating of Historical Chart.
[2017-11-05 20:27:52]
Ok. That works. Thank you for your immediate support.
