Date/Time: Thu, 16 Jan 2025 12:13:02 +0000
Relative Volume and CCI moved to Custom
View Count: 931
[2017-11-04 02:42:07] |
User299392 - Posts: 216 |
Why is it moved to custom studies? These are very popular studies and were always a part of Sierra Studies under studies. Any reason they are moved in the recent build over to custom? Does that mean Sierra will no longer support it? Under what circumstances does, Sierra, typically make such decisions? Please - will appreciate some direction in this regard. |
[2017-11-04 03:07:17] |
In version 1635, both of these are directly listed under Analysis >> Studies >> Studies Available.
