Date/Time: Thu, 16 Jan 2025 12:19:05 +0000
Trade demo and live in the same time
View Count: 832
[2017-11-03 17:11:16] |
User181005 - Posts: 1 |
Hello! Is it possible to trade demo and live in the same time? Id like to double the same trade with SL and TP on demo and live mode. I need to test some strategies in demo but sometimes I would like take the same trade in live mode too. Do you know is it possible and how to do that? Regards! |
[2017-11-03 19:08:21] |
This is only supported by using a separate instance of Sierra Chart: Using DTC Server for Data and Trading in Another Sierra Chart Instance One of them can be in Trade Simulation Mode and the other one not. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
