Date/Time: Wed, 22 Jan 2025 14:52:43 +0000
Display bid/ask difference on the chart header
View Count: 2831
[2017-11-03 15:46:24] |
grantx - Posts: 244 |
The current quote window contains only one piece of information I am interested in. The bid/ask difference. How do I get this to display in the chart header (or on the chart somewhere) instead of having the current quote window open the entire time? Thanks. |
Capture.PNG / V - Attached On 2017-11-03 15:44:26 UTC - Size: 18.68 KB - 476 views |
[2017-11-03 20:42:05] |
Will see if we can add this field to the Chart Header. For now use the DOM Graph for this information. Refer to: Trade Menu: Draw DOM Graph on Chart (Trade menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-03 20:42:21
[2017-11-04 07:17:52] |
nicktrader - Posts: 731 |
For that purpose I am using the Study "AskVolume Bid Volume Difference Text" (see pic with the settings)
Study AskVol BidVol Diff .png / V - Attached On 2017-11-04 07:15:53 UTC - Size: 39.32 KB - 530 views |
[2017-11-04 07:56:15] |
Yes, that is true. There is that study. We forgot about that.
[2017-11-04 08:12:30] |
But actually that study does not give them what they want. They want to know the difference between the Ask and Bid prices.
[2017-11-04 10:40:04] |
gomifromparis - Posts: 244 |
Add the Time and Sales Bid & Ask Study as hidden Add the Study Subgraphs Subtract/Difference to create ask-bid from the hidden study |
[2017-11-06 10:26:34] |
I am using these three studies to get the figure Im after: Time and Sales Bid & Ask (hidden) Study Subgraphs Subtract/Difference (hidden) Study Subgraph multiply How do I display the result in the header now? |
[2017-11-06 10:44:37] |
@Grants - I would do it on this way (quick and dirty solution). What you prepared in Region 2 make also in Region 1 but set the DrawStyle of the Subgraphs on "Hidden" and maybe you have to change the scale (Settinggs and Inputs) in Independent |
[2017-11-06 11:44:29] |
@nicktrader yep that does it! Thanks for your help. Untick 'display study name' to get the spread value only. Date Time Of Last Edit: 2017-11-06 11:47:18
[2018-10-08 20:06:11] |
AE16 - Posts: 31 |
Is there an easier way to do this now? If not would someone mind explaining how to get the end goal of the bid/ask spread in the header?
[2018-10-09 19:39:41] |
Is there an easier way to do this now? If not would someone mind explaining how to get the end goal of the bid/ask spread in the header? This is available in the current version. Refer to:Global Settings Menu: Customize Chart Header - Standard (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
