Date/Time: Thu, 16 Jan 2025 12:03:57 +0000
Strange behavior at Renko Bars
View Count: 924
[2017-11-03 09:17:26] |
Autotrade8 - Posts: 26 |
I use Renko Bars with a Ticksetting 5. Look at the rectangle with the latest candles. You should expect these bars to have the green color at least. Also look at the historical bars. On these ones, everything goes well. I've checked everything so many times now, but I do not understand what's going on. Please, can you help me. http://www.sierrachart.com/image.php?Image=1509700516945.png I found out that it has something to do with which Data Services you are using. With the SC Data all services it goes wrong. When I use FXCM CFD, no matter demo or real live everything goes well! pfff.......... It is my stupid fault.... I am using Daily High study and I am using color Bars to review Daily High / Daily Low in vertical scale. My apologizes! That's the reason why.... Date Time Of Last Edit: 2017-11-03 10:21:54
[2017-11-03 19:44:14] |
Also refer to: Renko Bar Charts: Renko Open, High, Low, Close Values And make sure you are running the current version of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
