Date/Time: Thu, 16 Jan 2025 12:02:01 +0000
IQ feed data back adjusted
View Count: 876
[2017-11-03 06:14:38] |
User504193 - Posts: 38 |
I have just subscribed to IQfeed historical data. Some of their symbols have back-adjusted continuous, and others are just continuous. If I select continuous futures - date adjusted from advanced tab 2, would this make any further adjustments to the data as displayed?
[2017-11-03 14:53:26] |
No, it would not. That setting does not affect IQ Feed symbols. Do not use the Chart >> Chart Settings >> Advanced Settings >> Continuous Contract option with IQ Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
