Date/Time: Thu, 16 Jan 2025 12:14:21 +0000
version 1633
View Count: 764
[2017-11-03 00:36:04] |
User63632 - Posts: 43 |
version 1633 will not open...Transact futures infinity. screen pops up "sierra charts .exe won't open. Worked fine with version 1632 today..Since I am unable to open SC..how do I revert back to 1632 with transact. Please. Thank you |
[2017-11-03 00:48:16] |
Never mind I was able to resolve...Cancel support request...I believe v1633 has a problem Thank you |
[2017-11-03 01:04:17] |
There is no issue like this with version 1633. Whatever the cause is it is not specific to 1633. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
