Date/Time: Thu, 16 Jan 2025 12:00:19 +0000
TPO Settings issue
View Count: 1076
[2017-11-02 18:31:00] |
CrazyNeena - Posts: 3 |
Hello There seems to be an issue with the IBR Extension Lines in the TPO Profile. The line style setting doesn't work. I would like to set those lines as Dash or Dot but it always shows up as Solid. Could you please advise Thank you for your help CN |
TPO Settings.PNG / V - Attached On 2017-11-02 18:29:44 UTC - Size: 48.79 KB - 303 views |
[2017-11-03 15:03:47] |
Don't forget about this! Support, Could you please comment on this? Thank you.
[2017-11-03 16:41:44] |
The Line Style is not supported for those particular extension lines.
[2017-11-03 16:55:40] |
Could it be supported in a future version? It seems like a good feature to have for a line. Thank you |
[2017-11-06 08:33:15] |
Yes we will add this setting.
[2017-11-06 08:33:17] |
