Date/Time: Thu, 16 Jan 2025 12:04:52 +0000
Normalize Calculation from Slope Function
View Count: 1813
[2017-11-02 17:10:02]
knoxville1915 - Posts: 38
Good afternoon,
I was wondering if there is any way to normalize the calculation from the slope function. I'm specifically getting the slope of a linear regression. Considering slope calculates the difference in price over time, the output range is starkly different between a $100 stock and a $10 stock - which makes it difficult to compare the two.
Perhaps there is a way to use percent change instead of price change? Alternatively, is there a way to calculate the angle in degrees?
[2017-11-02 17:37:09]
What do you mean by Slope function? Are you referring to a study?
We have no context for what you are referring to.
[2017-11-02 17:40:38]
In ACSIL, using sc.Slope.
[2017-11-02 18:09:56]
We are going to add a sc.CalculateAngle function which will give a result in degrees.
