Date/Time: Thu, 16 Jan 2025 12:15:25 +0000
Open Trading DOM For Chart: Unable to Remove Unknown Graphic/Chart Overlay from Chart
View Count: 732
[2017-11-02 16:14:38] |
User568791 - Posts: 13 |
To Whom It May Concern, Yesterday, the "Open Trade DOM for Chart" and "Open Trade DOM" were opened separately to explore the features and delve further. Further explored was the menu [M] button, etc. At some point an unknown graphic/ overlay was attached to chart (#20). Reference attachments: http://www.sierrachart.com/image.php?Image=1509638235112.png (#20 - horizontal bars, green above, red below, w/numerical values at top and bottom); http://www.sierrachart.com/image.php?Image=1509638955730.png (desktop layout w/DOM) Moreover, chart #21 appears per the "Open Trade DOM for Chart" upon opening it; however, it does not correspond to the selected chart (#20). Requested is the removal of the "unknown graphic/overlay" from chart #20 (upper left hand corner of desktop layout). How is this accomplished? I look froward to your reply. Jay |
[2017-11-02 17:30:27] |
What you are looking at is called the DOM Graph and that is documented here: Trade Menu: Draw DOM Graph on Chart (Trade menu) Moreover, chart #21 appears per the "Open Trade DOM for Chart" upon opening it; however, it does not correspond to the selected chart (#20). Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-02 18:02:05] |
Resolved!
