Date/Time: Thu, 16 Jan 2025 12:19:40 +0000
Possible Issue Stocastic RSI Indicator and Renko Bars
View Count: 628
[2017-11-02 14:29:00] |
User12041 - Posts: 25 |
I use a trading system that incorporates a Stocastic RSI Indicator set to (RSI Length: 14 / RSI Avg Type: Wilders Moving Avg / RSI Highest Lowest Length:14). Since renko bars have been rewritten this indicator is behaving very differently. Is there something that was done in the rewrite of the renko bars that would cause this indicator to give different results ?
[2017-11-02 17:08:07] |
Yes, this study is going to rely upon the true open and close values for each chart bar which are properly being set with Renko bars in the current version. We do not have any idea about what can be done at the moment. It will be considered though. Or you can modify it to meet your own requirements. Refer to: https://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-02 17:08:22
